SplitAttribute every nth character
  • Jul 5, 2018 8:46 PM UTC
  • 359 views
joshuadamron
Forum|alt.badge.img+9
Howdy,
I need to split a memo field (WrkDesc) that is over 2500 characters into several fields that are 255 characters or less (WrkDesc1, WrkDesc2, WrkDesc3, etc). Right now I laid out a bunch of SubstringExtractors which each grab a different section of the text (0-254, 255-508, 509-762, etc) and it works fine. However it seems like I should be able to do this within a single transformer like AttributeSplitter.
In the AttributeSplitter help it says "Alternatively, instead of using a delimiter character you can provide a string in the format #s#s#s, where each number is the length of the substring you wish to extract."
The way I interpreted that statement, for Parameter> Delimiter or Format String I inserted this: 254s508s762s1016s1270s1524s1778s2032s2286s2540s2794s and generated a list named _listWkDesc
However the output is a single list element _listWkDesc{0} with a copy of the memo fields entire original text. I had expected to see a bunch of list elements each with 254 character's of consecutive text.
Can someone point out the obvious and show me what I'm missing?
Thank you!
jdh
Forum|alt.badge.img+41
  • Jul 5, 2018 10:25 PM UTC
If you want to split it into 255 character strings, the expression should be 255s255s255s.
  • Jul 6, 2018 7:49 AM UTC
You can also use the StringSearcher with the following regex:
(.{1,255})
You will then get a list "_parts{}" containing each block of maximum 255 characters.
  • Jul 6, 2018 8:02 AM UTC
Alternatively, you can also use the StringSearcher with this regular expression. Split texts will be stored in the Subexpression Matched List.
(.{1,254})
  • Jul 6, 2018 8:06 AM UTC
(.{1,254})
Oops, I've fallen behind!
255? 254?
