Split polygon by lines
  • Nov 9, 2018 8:44 PM UTC
  • 5 replies
  • 1599 views
mr_fme
Forum|alt.badge.img+9
I need to split this polygon using as a reference the rows, how can I do this? These polygons are initially rows, which I transform into polygons using AreaBuilder. As a result it generates 2 polygons, however I need to fragment the polygon into more parts according to the rows.
Best answer by miladahmad
Try PolygonCutter from FME Hub
  • Nov 9, 2018 8:54 PM UTC
A possible way is: send the polygon and the lines together into an Intersector, and use an AreaBuilder to create split polygons from the lines output via the Intersected port of the Intersector. If the lines may not cross the polygon entirely, consider using the LineExtender to extend them beforehand.
  • Nov 9, 2018 10:53 PM UTC
  • Feb 28, 2020 3:17 PM UTC
FWIW, @takashi's solution is massively quicker than the PolygonCutter, for my application anyway. I did find I had to send the polygons through a GeometryCoercer to convert them to lines before passing into the Intersector, ie. the polygons and lines both need to be the same geometry before the Intersector outputs both via the Intersected port.
joshuadamron
  • Jul 20, 2021 5:21 PM UTC
Thanks for this tip it saved me some head scratching :-)
pdorio
Forum|alt.badge.img+8
  • Nov 23, 2023 7:17 AM UTC
This is my solution. Works great!2023-11-23_08h15_46
