split line with point intersect
  • Mar 23, 2020 9:24 AM UTC
  • 425 views
terezia86
Hello,
I would like to split the line with the intersected Points. Seems easy, but it does not work for me...
I have a lot of line which I merged together with a "NetworkTopologyCalculator" it looks that it works. After with aggregator I get 1 Line (what I wanted to). Then setted PointOnLineOverlayer. There I have the points, which intersected the Line. But the result from Overlayer is not as I needed.
does anybdy have any idea, whay it been splitted on "wrong" place, and not there where the are the points?
I get a sum of 840 lines, what is completely wrong.
Thanks a lot
Best answer by ebygomm
The line geometry is an aggregate and you have set the point on line overlayer to deaggregate, which is why you are getting the results you have. You probably want a linecombiner instead of an aggregator to achieve what you need to.
Forum|alt.badge.img+54
  • Mar 23, 2020 9:40 AM UTC
terezia86
  • Mar 23, 2020 9:58 AM UTC
Hello @ebygomm,
thanks for respond, it worked well, just there is still one little thing.
The line which are on the "crossing" are still separate. They should be also be joined. See the screenshots, please...
  • Mar 23, 2020 10:23 AM UTC
Hello @ebygomm,
You cannot have a single line geometry that has multiple lines with junctions and branches. It is only possible to represent this as a multiline/aggregate geometry. You may need to look at aggregating the data after using the point on line overlayer, but you'll need some method to ensure joins are not made where your points are.
