Split attributevalue into 2 different attributes
  • September 20, 2017
  • 7 replies
  • 1326 views
I have an attribute [complete] withe the value 1-A.
I would like to split that value to attribute [split1] with the value 1
and attribute [split2] with the value A
I've tried AttributeSplitter;AttributeTrimmer;AttributeCreator
Best answer by courtney_m
Use an AttributeSplitter with "Attribute to Split" set to complete, and Delimeter set to a dash (-). Then use a ListExploder to on the list attribute created by the splitter. You can then use a FeatureMerger to merge the records back together.
courtney_m
Forum|alt.badge.img+23
erik_jan
Forum|alt.badge.img+26
Or follow the AttributeSplitter by an AttributeCreator to create [split1] with value _list{0} and [split2] with value _list{1}.
fmelizard
Forum|alt.badge.img+22
Hi @kees_v, you can accomplish this using the AttributeManager as well. If you're splitting by only one character on each side of the -, you can set the transformer parameters as they are below:
courtney_m
Yeah, that will work better!
Thank you, exactly what i needed.
  • September 21, 2017
Alternatively, you can also use the AttributeRenamer to rename "_list{0}" to "split1", "_list{1}" to "split2", after splitting the source string with the AttributeSplitter.
Anyway, I think the AttributeSplitter would be a general way to split a string by a specific separator character or string.
Forum|alt.badge.img+54
You can also use the location of the - to determine the input for the substring which will work irrespective of the number of characters either side of the - (as long as there is only a single -)
e.g.
