I am interested in working with Spherical Panoramas in FME, Specifically Cyclomedia Panoramas (Cycloramas).
The Images are in Jpg format with No Coordinate System attached, alongwith an XML file containing Lat, Lon, Height and orientation with Coorsinate System. I can parse the XML and extract Info from it, read the Jpg from extracted Info. After that I'm stuck because image is Spherical in nature. I want to work on Image analysis and feature extraction with Raster toolkit.
Could someone point me to correct direction or guide me on it?
Thanks.
