SpatialFilter
  • Jul 6, 2021 9:34 PM UTC
  • 103 views
I want to filter out duplicate points from two point feature classes, however, every SpatialFilter configuration I have tried returns the duplicate points as failing all predicate test. Am I missing a configuration step?
DanAtSafe
Forum|alt.badge.img+23
  • Jul 6, 2021 10:37 PM UTC
Try only a single predicate - "Filter OGC-Equals Candidate" if the coordinates are exactly the same. If not then try a NeighborFinder.
NeighborFinder worked! I tried testing on a single predicate "Filter Equals Candidate" from Table 1, filtering points with identical coordinates from Table 2 (literally appended from Table 2 to 1 in a separate workspace) and that did not work but it could have to do with my slightly outdated version of FME Desktop. Thank you!
