Spatial relationship by column
  • Jan 30, 2019 1:14 PM UTC
  • 42 views
mr_fme
Forum|alt.badge.img+9
I am making a spatial relationship where there are several blocks for the same property, each lot of the same property has a unique value for the block column. If there is a spatial relationship of another file with one or more blocks, all blocks with the same block should appear as if there is a relationship. How to do this?
Best answer by ebygomm
If each feature has a list of the properties it relates to you can use a listcombiner (custom transformer) to assign a group
Forum|alt.badge.img+54
  • Jan 30, 2019 1:31 PM UTC
