Spatial Filter (?) - assign full area of intersected polygon to feature that contains the most overlapping area.
  • Feb 27, 2025 2:46 PM UTC
  • 207 views
p_c_20
Forum|alt.badge.img+9
I appreciate that’s a wordy question. Hopefully, this pic will clarify.
A and B - green polys, low detail at edge - are a dataset I am using to run into a SpatialFilter to determine areas of intersection with the more detailed dataset in pink (amber where there is overlap).
You can see that part of the upper example polygon I have coloured part of area 1 in blue, and sits mostly inside A. The smaller, black part of 1 sits inside B.
I want to join the entire area of the intersected polygon fully to the feature from the green dataset that contains the largest part of it - in this case, to A.
Any ideas how best to proceed? I currently foresee:
  • Check for intersection of area 1 with areas A & B
  • Calculate area of overlay
  • Test for largest
  • Join all of the area of 1 to A
    Feels like there may be a fair few transformers involved. It’s a national dataset. Just trying to figure out how best to do it. In Esri, I think there might be a simple option to ‘join to largest’…? (Not that I want to jump out of FME)
p_c_20
  • Mar 4, 2025 3:57 PM UTC
Ok, I’m thinking that lists may hold the answer.
donalmateer
Forum|alt.badge.img+13
Hi ​@p_c_20,
Thanks for the post!
From understanding your post I do believe there will be multiple transformers required to get to the correct result!
Here’s some transformers that should assist with the problem:
These should help with that you’re trying to achieve!
If you’re still having issues perhaps you could share your workspace and I could have a look into it and try resolve the issue!
Thanks!
p_c_20
  • Mar 6, 2025 8:46 AM UTC
Hi ​@p_c_20,
Thanks!
Thanks Donal. Figured it out. I couldn’t get Statistics Calculator to pass through the attributes of the merged feature that related to the largest area, so I ended up building a set of lists and doing some manipulation on those.
