Spatail Relator missing attribute values
Hi there,
I am joining a table to a dataset using FeatureMerger then supplying the results to SpatialRelator. When I test the results of the FeatureMerger the attribute values are all populated, however once I it SpatialRelator is added, the attribute values all turn to NULL.
I tried using AttributeRenamer, AttributeCreator and AttributeCopier to try get them across but with no look.
Any ideas?
Best answer by takashi
Hi @anne_shanahan, how do you have set the "Merge Attributes" parameters for the SpatialRelator?
  • October 8, 2016
I didn't have the "Merge Attributes" ticked! working now, thanks for the great suggestion
itay
Forum|alt.badge.img+19
  • October 8, 2016
Hi, you can save these settings by using the defaults button at the bottom and in case it is not necessary the deafults can be returned.
