Sorter is unable to hold more than 506 DTED features?
  • Aug 15, 2018 9:33 AM UTC
  • 7 replies
  • 104 views
I have a very simple workspace. A DTED reader which is set to read a few thousand .dt0 files. This feeds into a Sorter transformer, which sorts alphabetically on fme_dataset, and finally outputs to an Inspector
When exactly 506 features have entered the Sorter, all subseqent features gives the error
ERROR |DTED Plugin: Failed to open file Z:\raw\Elevation\Global\DTED0\dted\e016\s05.dt0.
WARN  |MULTI_READER(DTED_1): Skipping to next Reader
and only the first 506 features are output from the Sorter. This happens regardless of which .dt0 files are read, the limit is always 506 features.
This seems like a bug in the DTED reader to me, because a DEM reader does not give the same error.
I'm using FME 2018.1.0.0
Best answer by nampreetatsafe
Hi @mbu: We found a potential workaround for you while we are looking into your issue. I got the workspace to process all my DTED files by adding a RasterCheckpointer before the Sorter. This will essentially process/read-in each DTED file, save it to a temporary space, and close the original file. Let me know if this works for you in the meantime.
nampreetatsafe
Forum|alt.badge.img+14
Hi @mbu, sorry to hear about this error you're getting. Would you be able to tell me which OS you're using (i.e. Windows, Mac)? If Windows, are you using the 32-bit or 64 bit version of FME Desktop?
  • Aug 16, 2018 6:51 AM UTC
Hi @Nampreet , I'm using 64 bit Windows 10.
nampreetatsafe
I was able to reproduce this issue and have filed a ticket with our development team (reference: FMEENGINE-56260). We will post an update here once the issue is resolved.
Thanks @mbu for bringing this to our attention!
nampreetatsafe
jdh
Forum|alt.badge.img+41
  • Aug 20, 2018 10:40 PM UTC
fmelizard
Forum|alt.badge.img+22
  • Aug 29, 2018 5:20 AM UTC
I can also advise that this is fixed in FME 2019. We can't backport it to 2018.x, but the workaround above should get you through we hope.
nampreetatsafe
@mbu: I'm glad to inform you that the fix for this issue is now available in the FME 2019 Beta release (build 19150+).
