sort lines after clipping
  • June 1, 2017
  • 5 replies
  • 56 views
franco69
Forum|alt.badge.img+11
I have a route and clip it against areas....but i need the result in order of the flow direction of the route.....which parameter sorts me that because now the result is in no order and when i put a count on it it is no logical order.
So please help me... i think its no t abig problem for u guys
Thx
Franco
Best answer by david_r
Before Clipper:
  • MeasureGenerator
After Clipper
  • MeasureExtractor on first vertex (index = 0)
  • Sorter on _point_measure
  • MeasureRemover
Of course, if your route already has measures you should skip the MeasureGenerator and the MeasureRemover.
  • June 1, 2017
Are your features in the right order before the Clipper? If so, you could insert a Counter before the Clipper, and then a Sorter on the _count value after the Clipper. This would restore the original feature order.
franco69
  • June 1, 2017
i have only 1 feature (line) which is clipped against many areas and as a result i get many lines without the right order
  • June 1, 2017
Before Clipper:
  • MeasureGenerator
After Clipper
  • MeasureRemover
  • June 1, 2017
Hi @franco69, here is another approach, just for your information.
franco69
  • June 1, 2017
Thank you both very much !
