Snipper with Paths
  • Mar 16, 2018 3:14 PM UTC
  • 5 replies
  • 106 views
Hello there
I work with polylines in an ESRI Personal Geodatabase and want to shorten every polyline by distance using the Snipper. But for certain features there are more than one remnant. I guess, the reason is because features consist of Paths. Do I have to split Paths first and then use the Snipper for Lines and Arcs separately?
Thank you for every hint.
Best answer by fmelizard
@reto_meier Arc handling with the Snipper appears to have been fixed for FME 2017. The ArcStroker and GeometryRefiner are no longer required.
fmelizard
Forum|alt.badge.img+22
  • Mar 17, 2018 5:49 AM UTC
Hi @reto_meier You should be able to split paths. Are only path features resulting in more than one remnant? Can you send your workspace and sample data to www.safe.com/support ?
  • Mar 19, 2018 2:15 PM UTC
Thanks for your answer. I use the Snipper in a loop to cut a line regularly. The length of all snipped lines is higher than the input line. I could correct the effect using the ArcStroker and the GeometryRefiner before the Snipper.
I sent a simplified workspace with sample data to FME Support.
fmelizard
  • Mar 19, 2018 10:54 PM UTC
fmelizard
  • Mar 21, 2018 12:15 PM UTC
Thank you for your help.
