SliverRemover and arcs
  • Feb 21, 2018 3:30 PM UTC
  • 152 views
rob_z
when I apply the sliver remover after an areaonarea-overlay I noticed that arcs get dissolved.
I would like to remove slivers but keep arcs as arcs.
Repair method is set to "longest boundary".
It seems even arcs get dissolved (turned into line segments) for areas/arcs where there is no sliver.
FME 2017.1
Is that behaviour as designed? Did not find anything about in documentation.
Thank you, Rob
Best answer by daveatsafe
Hi @rob_z,
In FME 2018, the SliverRemover has been replaced by the AreaGapAndOverlapCleaner, which uses a different (and better) algorithm, and retains the arcs. You can download the the FME 2018 release candidate from our download page.
gio
Forum|alt.badge.img+15
  • Feb 21, 2018 5:19 PM UTC
yes, it strokes the arcs. Maybe use a geometryextractor to keep them (or an arcproperty extractor). Rebuild or reinstate the arcs after the sliverremover.
daveatsafe
Forum|alt.badge.img+24
  • Feb 21, 2018 5:48 PM UTC
Hi @rob_z,
rob_z
  • Feb 22, 2018 6:55 AM UTC
many thanks for your replies.
Rob
