simplify road network to remove islands?
  • Mar 5, 2019 2:48 AM UTC
  • 95 views
nicholas
Forum|alt.badge.img+14
I have a dataset of local roads, which I want to use for ShortestPathFinder.
The road network includes roads on islands, and those roads are not connected to the roads on the mainland.
Is there a transformer that can output only those roads that are part of the mainland road network? I want to eliminate the islands.
  • Mar 5, 2019 8:14 AM UTC
You can use the NetworkTopologyCalculator to find all the "self-contained" networks and then only keep the one with the largest number of roads (group by _network_id).
Forum|alt.badge.img+54
  • Mar 5, 2019 9:13 AM UTC
If your from-to lines are all points on the mainland network then there shouldn't be an issue using this as a network in the ShortestPathFinder without removing the island road networks
