SID to GeoTIFF conversion error
  • October 17, 2019
  • 9 replies
  • 91 views
fikusas
Forum|alt.badge.img+5
I'm getting the error message then converting SID file to GeoTIFF raster:
MRSID reader: MrSIDRasterBand::IRasterIO(): Failed to load image. mg2d internal error [8021]
MRSID reader: Failed to retrieve data from the source dataset
Any ideas how to solve this?
Best answer by sigtill
You can also read Pyramid layer 1 - instead of default 0 to get this in FME: Then it has the resolution original resolution / 2 = 1m.
itay
Forum|alt.badge.img+18
  • October 17, 2019
Hi @fikusas,
Can it be that the lack of coordinate system elements (datum and ellipsoid) are causing the issue?
fikusas
  • October 17, 2019
Hi @fikusas,
I think it can't be a problem, 'cause all other SID files aren't with defined coordsys either, but don't give this kind of error.
itay
  • October 17, 2019
From what I could find online it seems that some lines in the raster are corrupted. Not a big help but opening with GDAL provides the same error and since FME uses GDAL this is to be expected, so I think the issue is the input raster.
fikusas
  • October 17, 2019
Maybe the SID file is damaged, thus unreadable...
sigtill
Forum|alt.badge.img+25
  • October 17, 2019
I used Geoviewer from Lizardtech to open the file - free - https://www.extensis.com/support/geoviewer-9
When exporting it seems to give an error
So there is definitely something wrong with a part of the image although it can be viewed partially within the viewer.
I think you have to contact Lizardtech - they might have a MrSIDFix.exe or similar (seem to remember this from way back)
itay
  • October 17, 2019
yes that is what I think and @sigtill too..
sigtill
  • October 17, 2019
Exporting 1m resolution instead of 0.5m resolution works OK. So there is something wrong with the innermost layer. At least you got some of the data :)
Available 1 week, tif can be downloaded here : https://fil.email/ObiRCCUX
sigtill
  • October 17, 2019
fikusas
  • October 17, 2019
Thanks @sigtill !
