Shift line to a certain distance as per point
  • Jun 7, 2019 4:54 AM UTC
  • 115 views
parashari
Hello. I have to correct the road network geometry by shifting road polyline it to the point(that I created using FME to fix the road) beside it.
Below, the dark line is the existing line and to the left is the existing point at a certain distance. Now, I need to shift the full line geometry as it is overlapping the point and maintaining the same distance overall. The dashed line is the required line to be the output.
I tried Neighbourfinder to find the distance and stuck there. AnchoredSnapper(segment snapper) should work, but not purely working. Any ideas about how do I take it ahead.
Thanks!
Best answer by redgeographics
You could try a the OffsetCurveGenerator. It'll output a copy of the line offset to the specified distance in both directions (left and right) so then you'll just need to figure out which one you want. As you already have that point a SpatialFilter should do (unless you have really weird geometry)
Forum|alt.badge.img+63
parashari
  • Jun 7, 2019 9:30 AM UTC
Hi @redgeographics. This is an outstanding one. I used NeighbourFinder first and then used the OffsetCurveGenerator with the offset value of _distance from NeighbourFinder.
Thanks for your advice.
