Sharing my EPSG:31370 experience in relation to ArcGIS 10.7
  • December 13, 2019
  • 37 views
jelle
Forum|alt.badge.img+22
No real question, but I want to share some insights for my Belgian colleagues.
In FME, there are two 31370 coordinate systems: EPSG:31370 and Belge_72.Lambert_72_FME. They are exactly the same, except for the Esri WKT Description. The first one contains false easting and northing up to 5 decimals, the second one only three (like the OGC WKT).
Until ArcGIS 10.6, you have to use the EPSG:31370, with the additional decimals.
Starting from ArcGIS 10.7, ESRI changed the description of the coordinate system and applied the OGC values with 3 decimals.
Opening a filegeodatabase with EPSG:31370 in ArcGIS 10.7 leads to a 'custom coordinate system', not recognised by the software. Using the Belge_72.Lambert_72_FME coordinate system in FME avoids this issue.
I hope this post will help some people saving some time.
becchr
Forum|alt.badge.img+33
  • December 13, 2019
thank you, merci en bedankt
bertmeskens
Great find. Thanks, Jelle!
