Sharepoint file PATH
  • Nov 7, 2019 12:22 AM UTC
  • 94 views
timwarfe
Forum|alt.badge.img+10
Hi guys,
Is it possible to extract a list of PDF document path and filenames from an O365 Sharepoint folder as you would with a normal network drive?? FILE/PATH Transformer
Eg, Date, name, File Location, etc....
I can't seem to get this to work with a copy of the share URL for the folder. Maybe there's another way.
Thank you.
Tim
chrisatsafe
Hi @timwarfe,
If the drive is mapped to your machine, you should be able to use the Directory and File Pathnames reader to get the path to the files on your local drive - this works with a mapped Google Drive.
Alternatively, if you wanted to get the SharePoint URL, Mark's answer on this post might be helpful.
timwarfe
  • Nov 7, 2019 11:20 PM UTC
Thanks @chrisatsafe I'll check it out.
