Setting fixed decimal figures on data
  • October 30, 2014
  • 491 views
I am generating a textfile from positions and want to add decimal figures (zeroes) to fit with the formating. All data should have four decimal places:
e.g. turn 84.54 m should be 84.5400 m
The rounder transformers only remove decimal figures, but doesn't work for adding zeroes. I do not want to add data, just zero decimals.
/Burbank
Best answer by david_r
try the StringFormatter:
David
  • October 30, 2014
David
  • November 3, 2014
Thank you!
