Set 1km² boxes instead of my geometries
Hello
As a FME Rookie ive a question
I have three polygons less than 1km square
0.4 , 0.5 , 0.2 km²
I would like to know if there is a transformer to adapt every polygons to a 1km² box each ? , i only know Bufferer but is it possible to have the same surface in three different geometries ?
Thanks in advance !
joepk
Forum|alt.badge.img+20
  • January 12, 2024
Hello,
you can use a CenterPointReplacer to replace the three polygons with a point, and then use the Bufferer with a buffer distance of 500 meters and the End Cap Style set to Square.
This will result in a 1km² square polygon on the location of your input polygons.
Hope this helps.
  • January 12, 2024
Indeed ! thanks @joepk​
