ServerJobSubmitter does not submit
  • Jul 13, 2018 12:20 PM UTC
  • 61 views
dollargis
I have a submitter workspace that should call a child workspace.
The logfile says it does, however the child workspace never shows up in the job log.
The log of the submitting workspace says
FMEServerJobSubmitter(ServerFactory): http://xxxxxx:8084 - Running workspace 'gdp_import2k_worker.fmw' in repository 'Geoportal'...FMEServerJobSubmitter(ServerFactory): http://xxxxxx:8084 - Job #0 submitted
This "Job#0" raises my suspicion - is there something going wrong, maybe with user permissions or the like?
hi @dollargis,
What version of FME are you using, and also in your FMEServerJobSubmitter parameters is the Wait for Jobs to Complete set to Yes?
  • Jul 18, 2018 2:47 AM UTC
Also, check if the user of the FME Server connection that you have set to the FMEServerJobSubmitter has the privilege to run the child workspace.
richardatsafe
Forum|alt.badge.img+11
The "Job #0 submitted" error is usually the result of a discrepancy between the number of parameters or parameter types in the FMEServerJobSubmitter and what is in the published workspace. The FMEServerJobSubmitter will not automatically pick up changes to the child workspace.
If you have experiences this or another similar problem please vote up the idea for more FMEServerJobSubmitter logging.
