separating lines (shp)
  • July 16, 2018
  • 15 replies
  • 31 views
I have a set of lines that make up a set of polygons. Is there a way to separate lines that goes around the edge of data set? (see picture below, only yellow lines)
Thank you.
Best answer by david_r
Thanks for the feedback, didn't realize you needed to preserve the input lines. Try this:
getperimeter.fmwt
  • July 16, 2018
One way could be to try the AreaBuilder followed by the Dissolver and then the GeometryCoercer set to fme_line.
  • July 16, 2018
Perfect. That do the trick. Thank you @david_r.
  • July 16, 2018
Sorry, @david_r it only gave me one line. I need all the lines that make that one big polygon.
  • July 16, 2018
The result will depend on how accurately the lines are connecting, the should be 100% topologically correct for this to work. You may want to try a Snapper (segment snapping) with a small tolerance as well as an Intersector before the AreaBuilder, if necessary.
If that doesn't work, consider posting a small ffs-file here with some sample data so that we can give a more tailored response.
oscard
Forum|alt.badge.img+22
  • July 16, 2018
Does this come from a CAD source? If you want the yellow lines you could perform a filter using the color attribute.
  • July 16, 2018
Lines are snapped I tried adding Snapper with small tolerance and all the lines outputs as Untouched. I will upload some data. testdata.zip
  • July 16, 2018
Unfortunately all the lines are the same color. I changed it to showcase what I need because English is not my native language and sometimes people doesn't understand me at first. Thank you for your input @oscard
  • July 16, 2018
Seems to work fine for me:
Input:
Output:
Here's the workspace (FME 2017.1.2.1):
getperimeter.fmwt
  • July 16, 2018
Input:
Output:
getperimeter.fmwt
I get that too but it is only one line or polygon for me. I need to get lines that make that polygon.
In table view i need to get 100+ rows that represent lines. With this I only have one.
  • July 16, 2018
getperimeter.fmwt
  • July 16, 2018
getperimeter.fmwt
This is the one. Thank you @david_r and sorry for misunderstanding.
  • July 16, 2018
getperimeter.fmwt
The SpatialFilter can also be used instead of the LineOnLineOverlayer + Tester.
  • GeometyCorecer -> Filter
  • Original Line Features -> Candidate
  • Spatial Predicates to Test: "Filter Contains Candidate"
Another approach.
fmelizard
Forum|alt.badge.img+21
  • July 16, 2018
Hi @luckym You could also use just a TopologyBuilder after the AreaBuilder. The Universe feature will be a polygon of the outer edges.
  • July 17, 2018
Yes it gave the largest polygon but in my case i needed the lines that make that polygon. Accepted answer gave mi that. Thank you for your input @DanAtSafe it may help someone in the future.
  • July 17, 2018
Another approach.
Yes, this is another approach. Thank you @takashi.
