Separate outputs by multiple attribute value
  • Dec 13, 2019 5:53 AM UTC
  • 52 views
fikusas
Forum|alt.badge.img+5
Is it more efficient way to separate outputs based on multiple attribute value? In this case, I have 3 attributes and 3 testers, alongside 3 attribute renamers. The goal is to have all three attributes merged horizontally (by adding features) in one attribute, filtering out empty values. See the attached workspace.
bwn
Forum|alt.badge.img+26
  • Dec 13, 2019 6:31 AM UTC
If all the attributes start with "Material*" then send the Features to ListPopulator:
  • Set the "Source Attribute Prefix" to "Material"
This will create a single List out of all Attributes beginning with "Material".
Then send the output of this to ListExploder, and this will produce a feature set with a single Attribute of Material values.
