select mutually exclusive from offset polygons
  • Oct 30, 2018 11:10 PM UTC
  • 6 replies
  • 73 views
I've offset a number of yellow polys in this example 3 original inputs in the one layer.
I would like to subset this by selecting only the polygons that are mutually exclusive i.e. select only the polygons on the bottom left that do not overlap the other 2. Then all the polys on the top middle that do not overlap with the bottom left and right and so on.
Here are some of the end results that would work in teal. I did this manually but there would be more of each.
danilo_fme
Forum|alt.badge.img+58
  • Oct 30, 2018 11:26 PM UTC
Hello @tfsrichard
I think you could use the transformer AreaOnAreaOverlayer to check the overlaps between the polygons, and after use the transformer Tester to check the value of attribute overlaps = 0.
If you have questions, please share us the simple of data.
Thanks,
Danilo
  • Oct 30, 2018 11:28 PM UTC
Hello @tfsrichard
Thanks,
Danilo
Hi, this does not give the desired result with the attached input data.mutuallyexclusive.zip
jdh
Forum|alt.badge.img+41
  • Oct 31, 2018 4:00 PM UTC
I would try something with the SpatialRelator and Attributes that Must Differ (Unique Identifier on the original polygons)
danilo_fme
  • Oct 31, 2018 4:25 PM UTC
Thanks for the example
gio
Forum|alt.badge.img+15
  • Oct 31, 2018 4:46 PM UTC
Overlaying will not yield a result. Simply because in the sample data there will be some overlap for all objects.
AreaOnAreaOverlaying will give minimal overlap =1. And of course those are all the tiny outer edge bits.
You can:
1) Aggregator on Object_ID.
2) Sampler : first 1.
3) SpatialRelator: Sampled 1 as Requesor and NotSampled as Suplier. Test "Requestor Overlaps Supplier".
4) Tester _related_candidates = 0
like this spatialunrelatedsubsets.fmwt
5) next set. Sampler : evry Nth = 2 etc. For as many Object_ID'as are present. This you would need to iterate.
Grouped processing is possible if you create all permutations first.
requestor Supplier
135 76&66
66 135&76
etc.
In your sample data first test fails. There are no sets with 1 of each object_id that do not overlap
danilo_fme
  • Oct 31, 2018 4:51 PM UTC
Attached the Workspace template:
workspaceoverlaps.fmwt
