Select by Location with a negative search distance
  • Oct 17, 2017 2:20 PM UTC
  • 155 views
I need to replicate the Select by Location function in ARC.
The catch is that I need to be able to set a negative search distance. i.e. I need the polygons in the candidate layer to overlap the filter lay by at least 2 meters. see ARC settings below
I have tried the Spatial Filter and Spatial Relator however I cant see where you can specify a distance.
The Neighbour Finder lets you specify a distance but not a negative.
Please Help.
erik_jan
Forum|alt.badge.img+26
  • Oct 17, 2017 2:29 PM UTC
How about creating a Buffer (using Bufferer) with buffersize -2 (a negative buffer to decrease the size of the filter polygon) and use that in a SpatialFilter or a FeatureReader.
@erik_jan I tried that too, It wont let me do a negative buffer either, unless I am doing something wrong?
I can create the buffer in ARC and then use that but I was trying to avoid using more than one bit of software.
Thanks
fmelizard
Forum|alt.badge.img+22
  • Oct 17, 2017 10:51 PM UTC
Thanks
Hmm the -ve buffer worked for me in 2017.1 (attached) Which version of FME are you using?
-vebuffer.fmw
-vebuffer.fmw
2016.1
I don't have that transformer. Looks like I need an upgrade.
