Searching complete dataset for null values
  • Apr 3, 2018 12:31 PM UTC
  • 98 views
dustin
Forum|alt.badge.img+36
I'm trying to calculate the percentage of null values per feature class in a dataset. Null values are defined by '-99999' or 'noinformation' or 'No Information'.
I have hundreds of feature classes, each with hundreds of attributes named differently. So building a workbench calling out each attribute specifically would be very time consuming. This needs to be a dynamic solution.
So far I've tried an AttributeExploder followed by ListSearcher, but I'm having trouble calculating totals based on feature class.
  • Apr 3, 2018 12:40 PM UTC
Use the Group By in the StatisticsCalculator to calculate totals by group, in this case using the feature class name (fme_feature_type).
If your data is stored in a SQL database, a much faster solution would be to use a SQLExecutor with something like
select sum(
    case when your_attribute in ('-99999', 'noinformation', 'No Information') then 1
    else 0 end) * 100 / count(*) as percentage_empty
from your_feature_class
You can e.g. use the "Schema (any format)" reader to extract a list of all the feature classes and all the attribute names to feed into the SQLExecutor.
gio
Forum|alt.badge.img+15
  • Apr 3, 2018 2:39 PM UTC
If you use an attribute exploder you can create list grouped by attr_value.
Add all the list element counts for total. (better to count them prior to list building though, saves some effort)
Then test the attr_value for the criteria you mentioned. Add their counts and divide by total.
