Search list for values on multiple attributes
  • Mar 8, 2023 9:57 AM UTC
  • 5 replies
  • 307 views
tva
Forum|alt.badge.img+13
The listsearcher makes it possible to search in a list for a certain value on 1 Attribute.
Is it possible to do this (without listexploder) to search in a list for values on different attributes?
list example:
_names{0}.LC = Arabic
_names{0}.NA = Latin
_names{0}.PN = true
_names{1}.LC = Arabic
_names{1}.NA = Arabic
_names{1}.PN = true
I want to search in names list where PN = true & NA <> Latin and get that indexback. In this case it would be 1
If it's not possible in FME, how would I do this via python in FME then?
Best answer by david_r
For Python, do something like:
lc_list = feature.getAttribute('_names{}.LC') or []
na_list = feature.getAttribute('_names{}.NA') or []
pn_list = feature.getAttribute('_names{}.PN') or []
items = zip(lc_list, na_list, pn_list)
feature.setAttribute('found_index', -1)
for index, item in enumerate(items):
    if item[2] == 'true' and item[1] != 'Latin':
        feature.setAttribute('found_index', index)
        break
This will return the first found index in the attribute 'found_index'. The value will be -1 if not found. Depending on your testing it may be that you have to modify line 8 to read:
if item[2] == True and item[1] != 'Latin':
  • Mar 8, 2023 10:16 AM UTC
        break
Forum|alt.badge.img+54
  • Mar 8, 2023 11:20 AM UTC
Do you mean PN = true & LC <> Latin ? As this is true for both examples in your list
tva
  • Mar 8, 2023 11:48 AM UTC
Thanks for pointing this out. Adapted the question
  • Mar 8, 2023 11:54 AM UTC
Then this line in the code just needs changing
if item[2] == 'true' and item[0] != 'Latin':
to
  • Mar 8, 2023 12:08 PM UTC
Thanks, fixed my original answer accordingly.
