SDE - uncheck Allow Null property in table creation via FME
  • Jan 31, 2019 2:54 PM UTC
  • 131 views
annette2
Forum|alt.badge.img+11
I am creating a table in Oracle SDE with FME. Is there to uncheck the Allow NULL property of a field via FME Desktop? Or even a way to uncheck it after the table is created with FME within ArcGIS Pro Catalog? See screenshot below.
Thanks,
Annette
  • Jan 31, 2019 4:13 PM UTC
I have the impression this isn't possible using FME.
A possible workaround is to let FME create the table for you and then execute the necessary ALTER TABLE statements, for example:
ALTER TABLE your_table
ADD CONSTRAINT your_constraint_name CHECK(your_column_name IS NOT NULL)
You will have to execute this statement once for each column in your table.
annette2
  • Feb 5, 2019 5:52 PM UTC
It seems there is something in the SDE tables that govern the allow null option.  I also tried deleting all the records and via Pro setting it on the empty table but that didn't work.  I am going to open a ticket with esri.
https://community.esri.com/thread/25627
Another option would be to create the table via the Oracle spatial writer and then register it with SDE afterwards...but I have a nice workspace that applies domains etc so I won't try this just yet.
annette2
  • Feb 5, 2019 5:53 PM UTC
PS thank you for the answer.
ranga_tolapi
  • Mar 12, 2023 11:28 AM UTC
Understand that it's not possible 4 years ago, any chance is it possible now? 🤞
