https://safecommunity.force.com/CommunityAnswers?id=906a0000000d04XAAQ&v1=907a0000000coF0AAI&v2=Up& (https://safecommunity.force.com/CommunityAnswers?id=906a0000000d04XAAQ&v1=907a0000000coF0AAI&v2=Up&)
In the above question - the chosen solution ended up being the use of a workspacerunner. It was also remarked that another approach could be to use a "scripted parameter". (I assume this means the use of python??)
Could someone point me to an example of a scripted parameter being used in this way, or write a describtion?
