Schemamapper - multiple attributes to one
  • Oct 3, 2013 8:23 AM UTC
  • 10 replies
  • 79 views
sigtill
Forum|alt.badge.img+25
Hi!
I want to map multiple attributes to one using the Schemamapper:
Ie:
InputFeature:
FirstName: Roger
Lastname: More
OutputFeature:
FullName: Roger More
How should the SchemaMapper.csv look like?
FullName, FirstName + LastName ???
sigtill
  • Oct 3, 2013 8:28 AM UTC
Also tried:
@Value(FirstName)@Value(LastName),FullName
jelle
Forum|alt.badge.img+23
  • Oct 3, 2013 9:50 AM UTC
I always have to refer to http://fmepedia.safe.com/articles/Samples_and_Demos/Mapping-Schemas-using-SchemaMapper when using the SchemaMapper. Maybe, you can find your case in one of these examples?
best regards,
Jelle
sigtill
  • Oct 3, 2013 10:30 AM UTC
Hi! Thanks for the reply - however as far as I can see none of those cases describe my case.
I want to "merge" two input-attributes (Firsname AND Lastname) to a new attribute (FullName)
  • Oct 3, 2013 10:54 AM UTC
Hi Sig,
In my testing, Tcl "concat" command worked well. @Evaluate([concat @Value(FirstName) @Value(LastName)]),FullName   I'm not familiar with Tcl, cannot describe more details... By the way, why not use the StringConcatenator or the AttributeCreator?
Takashi
sigtill
  • Oct 3, 2013 11:22 AM UTC
Hi Takashi!
I am aware how to do it within FME - however the reason the SchemaMapper exist is to separate the mapping from FME itself (ie let a domain-expert do the mapping in EXCEL and the FME-expert take care of the rest:)).
sigtill
  • Oct 3, 2013 11:26 AM UTC
Another option I tried was to do the following in the CSV:
InputAttribute OutputAttribute Firstname FullName @Value(FullName) @Value(LastName)' FullName
However that did not seem to work either - as the last value overwrote the Firstname
  • Oct 3, 2013 12:34 PM UTC
Tcl "format" command also worked fine. It might be more flexible than "concat" command. @Evaluate([format "%s %s" @Value(FirstName) @Value(LastName)])   I agree with you. There could be such a situation - dividing roles by domain-expert and FME-expert.
sigtill
  • Oct 3, 2013 1:07 PM UTC
Ah,great - now it works with both options! Just had to put the formula in "DEFAULTVALUE" - column and not InputAttribute. Thank you
  • Oct 4, 2013 3:19 AM UTC
I learned Tcl a little more. This expression also worked, for what it's worth.
@Evaluate([return "@Value(FirstName) @Value(LastName)"])
I've never used Tcl so far, but it seems to have big availability especially for string processing.
  • Oct 4, 2013 6:18 AM UTC
P.S. These are better if FirstName or LastName may contain a special character (" [ ]  <white space> etc.).
@Evaluate([return {@Value(FirstName) @Value(LastName)}]) @Evaluate([format "%s %s" {@Value(FirstName)} {@Value(LastName)}]) @Evaluate([concat {@Value(FirstName)} {@Value(LastName)}])
