Schema Mapper - Unexposed Attributes
  • Sep 27, 2019 12:30 PM UTC
  • 129 views
tomw202
Forum|alt.badge.img+4
Hi All,
I've got a situation where I am dynamically feature reading in any number of feature types, and exporting via the generic port. I then have a list of all possible feature types and the schema mapping required. Am I right in assuming the SchemaMapper requires attributes to be exposed to be "mapped"? I'm looking for a solution where the SchemaMapper can see the dynamic unexposed attributes and map them.
Best answer by takashi
Hi @tomw202, I don't think it's essential that attributes to be mapped are exposed. The SchemaMapper should work based on an external table defining schema mapping even if the source attributes are unexposed.
  • Sep 27, 2019 12:38 PM UTC
tomw202
  • Sep 27, 2019 12:52 PM UTC
You're correct! I had a simple error in my mapping file that meant they were not working. But unexposed attributes work fine :)
