Scan QR-code within workspace, is there a way?
  • November 15, 2024
  • 63 views
tooli11
Participant
Wondering if FME can read QR-codes from images. Input is folder with images with QR-codes and some other content. FME should determine where to save those files based on the QR-code so just be able to read the code within workspace. Has anyone tried doing something like this?
Best answer by redgeographics
There's QR reading API's that you can use, I found this one but there's bound to be more. You can use the HTTPCaller to call them and send the image to them.
Forum|alt.badge.img+62
  • November 15, 2024
danilo_fme
Forum|alt.badge.img+53
  • November 15, 2024
Great job!
