Scaling rasters - question from FME WT Singapore
  • May 13, 2019 5:29 AM UTC
  • 163 views
darkspatiallord
Forum|alt.badge.img+8
A client at the FME World Tour in Singapore has the following question
If I have 2 rasters (jpegs) of same image BUT different resolution and scale
What would be the process in FME Workbench to align them
@darkspatiallord @brianatsafe
Best answer by gio
@darkspatiallord (I see there are 2 dark lords out there..)
Use an Affiner to move them to a common origin and then use a Scaler.
This will scale the spacing but will maintain the resolution, which is defined as the number of rows and columns.
To change resolution you can use a RasterResampler, set to columns and rows.
You have to maintain the aspect ratio though, else you'll warp your image.
  • May 13, 2019 5:36 AM UTC
Seems like RasterResampler would work: http://docs.safe.com/fme/2019.0/html/FME_Desktop_Documentation/FME_Transformers/Transformers/rasterresampler.htm
The documentation also mentions a whole bunch of other Raster Transformers that can be used for more specific purposes.
gio
Forum|alt.badge.img+15
  • May 13, 2019 3:45 PM UTC
