Scale and move one bounding box to be within another
  • May 21, 2013
  • 17 views
As the title, I start with a box which I eventually split into tiles. This box needs to be scaled, possibly moved all whilst maintaining the aspect ratio to fit into the reference box.
How should I proceed?
Cheers,
  • May 21, 2013
Using the BoundsExtractor, you can get xmin/max, ymin/max values of a bounding box. In addition, if your final purpose is the tiling processing, the Tiler might help you without scaling.
Takashi
  • May 21, 2013
... if 'scale' means 'make a box bigger or smaller', have a look at the Scaler transformer.
  • May 21, 2013
to add to Takashi's suggestions: you can use the Offsetter to move your features given a relative offset distance (delta).
David
  • May 21, 2013
Hi Pat,
Not exactly knowing what you want to do with the boxes, but from my own practical experience: not managing the box boundaries, but managing the centroid with scale and aspect ratio (and a derived function delivering you the box dimensions), gives a much simpler approach and delivering a  robust code solution.
Marc
