Saving FME Server Topic as an attribute value (FME Server)
  • Mar 6, 2018 6:36 PM UTC
  • 50 views
Hello,
I have several publications in FME Server that are monitoring for incoming emails. The publications are subscribed to different topics. I am making a master log (in SQL) of all incoming emails for all the topics.
When I start the monitor for a topic in FME Server, I get this sample JSON notification output:
{ "email_publisher_subject": "[this is the subject]", "email_publisher_sent": "Fri Jun 30 14:41:19 EDT 2017", "email_publisher_content_type{1}": "text/html; charset=\\"iso-8859-1\\"", "email_publisher_from": "testemail@gmail.ca", "email_publisher_content_type{0}": "text/plain; charset=\\"iso-8859-1\\"", "ws_topic": "Document_Incoming (EMAIL)", "email_publisher_received": "Fri Jun 30 14:41:32 EDT 2017", "email_publisher_to": "destination_email@gmail.ca", "email_publisher_content{0}": "[email content goes here]", "fns_type": "email_publisher" }
I want to capture "ws_topic" as an attribute. If I save this notification to a text of JSON file and run it via a FME script by using a JSON reader, the ws_topic is saved in the database with the value "Document_Incoming (EMAIL)". But when I upload the same script to FME Server and map the source to the Notification Message, ws_topic comes up NULL. All other parameters are logging fine.
I don't understand what I am doing wrong here. Any help will be appreciated.
Best answer by fariyafarhad
I managed to find my own solution!
There are an FME Server Parameter called FME_TOPIC. I created an attribute having the value of that parameter and output that in the log. Works perfectly!
  • Mar 6, 2018 7:22 PM UTC
