S3Connector and download only folders that contain 2025
  • Jun 5, 2025 12:34 PM UTC
  • 113 views
peterhearns
Forum|alt.badge.img+8
Good morning,
I have a folder in an S3 bucket that contains a folder for each day of the year and each of those folders contain about 24 files. Since I need to download the data in order to process it, is there a way to only download the folders that contain the word “2025”?  I have not been able to format a wildcard that works for a folder. I could also potentially use a wildcard to select the files, if there is a way to do that.
Thank you,
Peter
Best answer by david_r
I share the opinion of ​@carlm, you should use the option Include subfolders = No to only read the first level, i.e. the folder names, then filter (e.g Tester) before reading the individual folder contents.
carlm
Forum|alt.badge.img+23
  • Jun 5, 2025 12:54 PM UTC
You will need to use the List function of the S3Connector first, use a tester to filter the file containing the 2025 file and then Download the file that you need.
  • Jun 5, 2025 12:58 PM UTC
peterhearns
  • Jun 5, 2025 1:07 PM UTC
Excellent, thank you @david_r and @carlm for the quick responses.  This worked perfectly and now I don’t fill up my local drive!  I wish I could select both as the Best Answer.
