Running SQLExecutor with blank Parameters
  • May 28, 2018 2:36 PM UTC
  • 33 views
I have an SQLExecutor that uses some Public Parameters in the WHERE condition. If the user leaves the Parameter blank then the query look for blank "" fields. How can I dynamically control what goes into the WHERE condition, so when the parameter is blank we exclude that condition?
Thanks
  • May 28, 2018 2:40 PM UTC
The easiest solution may be to test for a blank where-statement and replace it with something like
WHERE 1=1
