Running MapInfo MapBasic scripts with FME?
  • Apr 11, 2016 11:24 AM UTC
  • 86 views
seanob
Forum|alt.badge.img+4
Can a FME workspace be created to run a series of MapInfo MapBasic scripts?
mark2atsafe
Forum|alt.badge.img+59
If you can run a MapInfo script from the command line (and this page and this page tell me that you can) then you should be able to use the SystemCaller transformer in FME to do this.
Alternatively, you could use a shutdown script (see Navigator Window > Workspace Parameters > Advanced) to run such a command.
It depends on whether you need the workspace to finish before the script is executed. If you do, then use a shutdown script. If not, use a SystemCaller transformer.
Hope this helps
Mark
seanob
  • Apr 11, 2016 3:53 PM UTC
Thank you very much for your response. I'll give it a go and let you know how I get on.
