Run Workspace by command line
  • Aug 1, 2018 3:44 AM UTC
  • 10 replies
  • 481 views
mr_fme
Forum|alt.badge.img+9
I want to run the workspace by command line. But my workspace don´t have source dataset and output dataset. I´m using just creator and HttpCaller for download the zip file.
I haven´t experience to run workspace by command line. I was created the batch file like this:
fme.exe C:\\Users\\FME\\Desktop\\Workspace\\download.fmw LOG_FILENAME c:\\fme.log
But nothing happens..:(
Best answer by takashi
If the actual workspace file path (C:\\...\\...fmw) contains spaces, you have to quote it by double quotations.
Also, I don't think the dash leading LOG_FILENAME is necessary.
  • Aug 1, 2018 3:52 AM UTC
  • What result would be shown on the command prompt window, if you run the workfpace through cmd with the same command line?
  • Have the log file "c:\\fme.log" been created?
fmelizard
Forum|alt.badge.img+22
  • Aug 1, 2018 5:58 AM UTC
Hi @mr_fme Did you forget the dash? It should be -LOG_FILENAME
mr_fme
  • Aug 1, 2018 3:08 PM UTC
There´s no log file created!
The CMD show me the message below
Expected an even number of command line arguments, instead got 3 for command line: >> `embargos.fmw' `-LOG_FILENAME' `C:\\fme.log' <<Program TerminatingTranslation FAILED.
  • Aug 1, 2018 3:16 PM UTC
mr_fme
  • Aug 1, 2018 4:30 PM UTC
@takashi
You help a lot. This command work properly, but when I paste in .bat file nothing happens.
C:\\FME_2017\\fme.exe "C:\\Users\\Smith\\Workspaces\\Fluxos\\down river.fmw" -LOG_FILENAME c:\\fme.log
  • Aug 1, 2018 11:01 PM UTC
Sounds strange. The bat file should work if its content is the command line which you were able to execute through command prompt successfully.
How did you run the bat file?
mr_fme
  • Aug 2, 2018 12:31 AM UTC
Hi @Takashi,
I´m testing now in Windows 7, and work properly. The problem in bat file occur only in Windows 10 :(.
Thank´s
  • Aug 2, 2018 4:27 AM UTC
Run the batch file from CMD in your Windows 10 machine, and check what message would appear.
Just type the batch file path (quote the path with double quotations if it contains spaces) on CMD window and press the Enter (Return) Key.
mr_fme
  • Aug 2, 2018 11:23 AM UTC
My problem has been solved. I put a command line directly in the Windows 10 Task Scheduler and ran perfectly, it was what I needed. You do not need to create a batch file now. However, what is done based on execution rules for the process of running a mapping tool to run a program, for example, runs.But a usage resolution or task scheduler has already solved the problem for now.
Thank you very much for your attention.
