Run FMEFactoryPipeline repeatedly with PythonCaller
  • Mar 24, 2016 1:55 PM UTC
  • 8 replies
  • 110 views
verdoodtdries
Forum|alt.badge.img+23
Hellow fellow FME-users,
I'm trying to run FMEFactoryPipeline repeatedly within a PythonCaller.
After some iterations it stops running unexpectedly and FME is only providing me the unhelpful error message: "Error running translation".
I think the order of the function I'm calling on the pipeline factory is wrong.
This is the order I'm using right now:
# initialize pipeline
pipeline = fmeobjects.FMEFactoryPipeline()
# Add pipeline factory (spatialrelator in my case)
pipeline.addFactory()
# Push features through the pipeline
pipeline.processFeature()
# Execute the pipeline
pipeline.allDone()
Or I'm forgetting to call a certain function on the pipeline object.
Documentation on FMEFactoryPipeline can be found here: http://docs.safe.com/fme/html/FME_Objects_Python_A...
I attached an example workspace.
Has someone experience with this issue?
Thank you very much.
Best answer by larry
Hello,
SAFE confirmed that there is a bug with 2014 SP5, 2015 and 2016.
They are expecting a fix in 2016.1.
Regards,
Larry
  • Mar 25, 2016 1:15 PM UTC
I have the same issue as you with 2015 and 2016. I'll try to find the source of the problem and come back to you later today or early next week.
  • Mar 25, 2016 6:54 PM UTC
Hello,
I played a bit with the factory code and it seems to be an issue with 2015 and 2016.
The attached workspace runs fine in 2014 but crashes 2015 and 2016.
I submitted the workspace to SAFE for investigation (case #C113361).
Regards,
Larry
  • Mar 25, 2016 7:00 PM UTC
Hello,
Regards,
Larry
@daleatsafe Can I add a reference to the SAFE case number here?
fmelizard
Forum|alt.badge.img+22
  • Mar 25, 2016 7:04 PM UTC
Please do. We'll want to give this a look and will in any case, but no problem having a reference in here.
  • Mar 25, 2016 7:06 PM UTC
Done, thanks.
  • Apr 4, 2016 12:49 PM UTC
Hello,
Regards,
Larry
verdoodtdries
  • Apr 5, 2016 7:24 AM UTC
Hello,
Regards,
Larry
Thank you very much Larry. I'm looking forward to the new release.
  • Apr 21, 2016 2:56 PM UTC
Hello,
Regards,
Larry
Just tested FME Desktop 2016.1 Release Candidate (build 16489) and this is fixed.
Can be downloaded here:
https://www.safe.com/support/support-resources/fme-downloads/beta/
