Rounding time to 5 minute intervals
Hi
I have a file with the following layout:
N19111N,,287026.00,407599.00,2016-02-01 06:58:33,25.0,0.0,0.4
N19111N,,287026.00,407599.00,2016-02-01 07:03:33,25.0,1.0,25.0
N19111N,,287026.00,407599.00,2016-02-01 07:08:33,27.0,1.0,27.0
N19111N,,287026.00,407599.00,2016-02-01 07:13:33,28.0,3.0,9.4
N19111N,,287026.00,407599.00,2016-02-01 07:18:33,24.0,1.0,24.0
Is there an easy expression to round down to the previous 5 minute intervals like so:
N19111N,,287026.00,407599.00,2016-02-01 06:55:00,25.0,0.0,0.4
N19111N,,287026.00,407599.00,2016-02-01 07:00:00,25.0,1.0,25.0
N19111N,,287026.00,407599.00,2016-02-01 07:05:00,27.0,1.0,27.0
N19111N,,287026.00,407599.00,2016-02-01 07:10:00,28.0,3.0,9.4
N19111N,,287026.00,407599.00,2016-02-01 07:15:00,24.0,1.0,24.0
Thanks
Best answer by takashi
Hi @aburns, how about this?
  1. DateFormatter (1): Convert the datetime string to the number of seconds elapsed from the epoch  (Destination Date Format: %s).
  2. ExpressionEvaluator or AttributeCreator: Divide the value by 300 seconds (= 5 minutes), truncate decimal places, and multiply by 300.
  3. DateFormatter (2): Restore the original datetime format (%Y-%m-%d %H:%M:%S).
Assuming that the time value converted by the first DateFormatter is stored by an attribute called 'time', the expression is:
@int(@Value(time)/300)*300
  • June 28, 2016
  • June 28, 2016
Here's one possible solution using string manipulation and lists:
  • June 28, 2016
Always fun to see how differently you can do things in FME and still get the same results :-)
  • June 28, 2016
Yeees, me too :-) There is more than one way almost always. The StringReplacer can be used to replace the last four characters appropriately.
  • Text To Match: (....)$
  • Replacement Text: <0:00 or 5:00 according to the number of fourth from last>
  • Use Regular Expressions: yes
  • June 28, 2016
Hi
Thanks for the replies. I am still experiencing issue:
Any ideas where im going wrong?
Thanks
  • June 28, 2016
aburns wrote:
Hi
Thanks
Maybe try setting source date format to "%s" in the last DateFormatter? FME is not very good at guessing date formats, in my experience...
  • June 28, 2016
aburns wrote:
Hi
Thanks
@aburns, you have to specify the Source Date Format parameter in the second DateFormatter. Try setting '%s' there. See also the help doc on the DateFormatter to learn more about date/time formats
  • June 28, 2016
@takashi, @david_r
Spot on, missed that! Sorted that out nicely!
thanks both, appreciated all the replied as we can all see we can get to the same endpoint using different method. I didnt even think of the string replacer and regex.
Regards
Andy
  • June 28, 2016
This works nicely and very easy.
