Reverse string at certain caracter
  • May 31, 2023 3:03 PM UTC
  • 134 views
antoine.prince
Forum|alt.badge.img+4
I have a string column containing lake names in the format ''Blue, Lake'' and I would like to reverse the format to ''Lake Blue''. I somehow can't find a way to reverse a string at the comma.
Is there an easy way to accomplish this using string functions in FME ?
Best answer by dustin
I would use an AttributeSplitter to split on the comma, which will create a list. Then in an AttributeCreator, build your new attribute using the list elements.
dustin
Forum|alt.badge.img+36
  • May 31, 2023 3:17 PM UTC
antoine.prince
Thank you! That was super easy to implement and worked perfectly.
Forum|alt.badge.img+54
  • May 31, 2023 3:29 PM UTC
You could also use a StringReplacer, match the word before the comma in one group and the word after the comma in another group and then replace with the matched groups in reverse order
dustin
  • May 31, 2023 3:33 PM UTC
That is slick!😎
