Retriev errors
  • December 31, 2014
  • 8 views
farfar
Forum|alt.badge.img+12
Hi all,
I've a workbench with one reader and one writer. if the traitment is issue i would retrieve the raisons or logs into file (my writer or another file).
Any idea?
Thanks an advance.
FarFar
Best answer by takashi
Hi FarFar,
If you want to write only error messages into a file automatically, define a function to collect error messages in the Sartup Pytnon Script, and write the messages in the Shutdown Script. For example:
# Startup Python Script
import fmeobjects
# Error message collector.
errorMessages = []
# Callback function
def collectErrorMessages(severity, message):
    if severity == fmeobjects.FME_ERROR or severity == fmeobjects.FME_FATAL:
        errorMessages.append(message)
# Set the function to the FME LogFile object
logFile = fmeobjects.FMELogFile()
logFile.setCallBack(collectErrorMessages)
logFile = None
# Shutdown Python Script
if 0 < len(errorMessages):
    f = open('C:\\\\tmp\\\\error_log.txt', 'w')
    for msg in errorMessages:
        f.write('%s\\n' % msg)
    f.close()
Takashi
  • December 31, 2014
Hi FarFar,
import fmeobjects
errorMessages = []
# Callback function
logFile = None
    f.close()
Takashi
