I have a bunch of ZIP files which we download the contain data in 3 formats, shape, csv and file gdb. The zips also contain numerous other files such as pdf and xml, which we don't need to read.
Now the tricky bit, I am using a PATH reader to check a directory to see what ZIPs are there and to only load the ones that have arrived in the last 24hrs. The load is triggered in a Sub workbench where the Path is passed to a FeatureReader set to Generic. I can add I file type filter to the path that is passed by adding [**\\*.shp], for example to the path of the zip found by the PATH reader and can read the ZIP 3 times with a different filter each time by building this string
""@Value(path_windows)[**\\*.shp]" "@Value(path_windows)[**\\*.csv]" "@Value(path_windows)[**\\*.shp]""
but can't work out how to add filters for csv and gdb to read the file once and look for shp, csv or gdb.
The above works, but I get error messages for the iterations that don't find the file type filtered for, which is messy.
I could hard code the file type for each file, but want to future proof for possible changes in the future
