Resetting Counter to zero within a group
  • May 26, 2020 10:35 AM UTC
  • 169 views
I appreciate this is an additional question on this topic, but I am struggling to get the Counter transformer to reset to 0 in my particular example.
I have a dataset along the following lines:
Site,Date,Event
Site1,20200101,0
Site1,20200102,0
Site1,20200103,1
Site1,20200104,0
Site2,20200101,0
Site2,20200102,4
Site2,20200103,0
Site2,20200104,0
I would like to set a Counter for each site to essentially calculate a value for "how many days since last event", i.e. the Count +1 for each 0 and resets when it encounters a non-0 value, resulting in:
Site,Date,Event, Days Since Last Event
Site1,20200101,0,0
Site1,20200102,0,1
Site1,20200103,1,0
Site1,20200104,0,1
Site2,20200101,0,0
Site2,20200102,4,0
Site2,20200103,0,1
Site2,20200104,0,2
I'm struggling to have the Counter reset to zero, perhaps I should be looking at an alternative approach, as per the advice from @takashi this Knowledge base article?
https://knowledge.safe.com/questions/5287/counter-by-group-but-reset-to-1-within-a-group.html
Many thanks in advance :)
Best answer by ebygomm
Yes, in this case I'd be using the adjacent attribute functionality in an attributecreator rather than using the counter
Forum|alt.badge.img+54
  • May 26, 2020 10:56 AM UTC
gazza
  • May 26, 2020 8:04 PM UTC
If you set the Counter Name to counter_@Value(Site) you get a separate counter for each site.
  • May 26, 2020 8:34 PM UTC
Hi, thanks for the suggestion, this worked perfectly!
