Reprojector
  • Nov 12, 2021 8:23 AM UTC
  • 90 views
arash_hokm
Forum|alt.badge.img+8
Hi FME Community,
I would like to reproject my file into another coordinate system. I am looking for correct coordinate system. ArcMap gives me a correct result. FME gives me wrong coordinate after the reprojector.
the pictures show which coordinate systems I used in FME and ArcMap. In addition, my file belongs to Germany.
Thanks a lot in advance
ArcMapFME
Best answer by nielsgerrits
As an alternative you can use the EsriReprojector to use the Esri reprojection library to reproduce an Esri reprojection.
nielsgerrits
Forum|alt.badge.img+67
  • Nov 12, 2021 8:53 AM UTC
tomfriedl
Forum|alt.badge.img+14
  • Nov 12, 2021 9:35 AM UTC
The coordinate system ETRS in Germany (Country NRW) has the EPSG-Code 25832.
arash_hokm
  • Nov 12, 2021 12:12 PM UTC
@nielsgerrits​ very good. it worked. Thank you
