Replicate value for all records
  • Jan 4, 2019 8:24 PM UTC
  • 212 views
mr_fme
Forum|alt.badge.img+9
I have some features that contain the especific date, but in others features from the same file no have date value...
How I replicate the date for all by fme_basename?
I´m reading many files at once and dates are different for each file.
Thank´s
erik_jan
Forum|alt.badge.img+26
  • Jan 4, 2019 8:50 PM UTC
It should work with this approach:
Hi @mr_fme,
Alternatively you could use Adjacent Attribute Handling in the Attribute Manager to achieve this.
  1. Add an Attribute Manager and Enable Adjacent Feature Attributes. Change the value for Number of Prior Features to 1.
  2. For the Date column select 'Conditional Value' for the Attribute Value. Change the Pass Criteria to AND then set two test clauses:
    fme_basename = feature[-1].fme_basename
    AND
    date Attribute is missing
    Then for the new attribute value set it to feature[-1].fme_basename.
I believe this would also give you the desired result.
mr_fme
  • Jan 6, 2019 2:48 AM UTC
@erik_jan,
Your suggest definitely helped me a lot.
Thank´s
