Replacing a point with an arrow symbol
  • October 30, 2013
  • 5 replies
  • 249 views
Hi folks,
I have a series of 2D points writing out to a geospatial PDF.  The points are hyperlinks that load up GPS photos in the default image browser.  The points have a rotation attribute, captured by the camera compass.  I want to replace the points with an arrow symbol with the relevant rotation, for once easy in ArcGIS, but stumped in FME!
Thanks.
Amit
fmelizard
Forum|alt.badge.img+22
  • October 30, 2013
Hi Amit,
Why the do it in FME?
  • October 30, 2013
Hi Italy, probably a bit of misleading comment!  You can't output the content to a PDF, can only use in ArGIS which the client doesn't have.
  • October 30, 2013
I just tested the following:
  • 2DDirectionExtender (from FME Store) to convert point to rotated line
  • Labeller
For the text of the labeller I used an arrow symbol that I copy/pasted from the windows Character Map application (Arial font): ?
I'm sure there are variations / other ways.
David
  • November 1, 2013
Hi David,
Thanks for the reply, that almost works!  I created a new attribute and made it the arrow symbol however it seems it's not compatible with the PDF writer.  If I connect a visualiser or write to DWG, it writes out the arrows but not to PDF.
Amit
  • March 30, 2015
Along these lines, is there a way to replace the "dot" symbol for a feature point in the Data Inspector?  I was able to use the procedure described above using the LabelPointReplacer, but it puts a symbol beside the actual point location represented by a dot within the data inspector.
