ReplaceRegEx failing in AttributeManager
  • Mar 14, 2019 6:56 AM UTC
  • 159 views
Hi all,
I'm trying to clean latlongs using RegEx in the AttributeManager but I'm getting below error.
AttributeManager_2: Expected signature @ReplaceRegEx(UTF8,UTF8,UTF8,[BOOL]) but received ReplaceRegEx("latitude" content="52.132932,("latitude" content=)
Feature Type: `AttributeManager_OUTPUT'
Attribute(encoded: UTF-8): `LAT' has value `"latitude" content="52.132932'
Attribute(string) : `fme_feature_type' has value `Creator'
Attribute(string) : `fme_geometry' has value `fme_undefined'
Attribute(string) : `fme_type' has value `fme_no_geom'
Coordinate System: `'
Geometry Type: IFMENull
AttributeManager_2 (AttrSetFactory): An error occurred while evaluating the above expression. If the failed expression is arithmetic, check to ensure there is a numeric value specified as the substitution value for null, empty and missing attributes.
AttributeManager_2 (AttrSetFactory): AttributeManager_2: Failed to evaluate input expression: @ReplaceRegEx(@Value(LAT),"("latitude" content=")(\\d*\\.\\d*)",\\2)
Settings and example workbench:
LAT attribute with this value:
AttributeManager setting:
Thanks,
Ed
Best answer by takashi
Hi @edhere, try escaping the inside double quotations with back slash.
@ReplaceRegEx(@Value(LAT),"(\"latitude\" content=\")(\d*\.\d*)",\2)
FME String functions require escaping double quotations if they are within a string parameter surrounded by double quotations. See here to learn more: String Functions
I would recommend you to use the StringReplacer in this case.
  • Mar 14, 2019 7:33 AM UTC
  • Mar 14, 2019 11:06 AM UTC
Thanks @takashi!
I should have RTFM-ed this ;-)
Best,
Ed
