Replace z-coordinates of a line's start and end nodes with values from attributes?
  • Aug 21, 2019 1:48 PM UTC
  • 70 views
jonas_nelson
Forum|alt.badge.img+34
Hi!
I have a set of 2D polylines, where I want to assign different z-values on the start and end node coordinates. The values I want to set are stored as attributes (let's call them "z_start" and "z_end").
Is there an easy way to achieve that?
Best answer by ebygomm
You can use a 3d Interpolator with the starting elevation set to z_start and the ending elevation set to z_end if you don't mind the intermediate vertices having a z value somewhere in between
Forum|alt.badge.img+54
  • Aug 22, 2019 10:54 AM UTC
